Bayou 220 miss/cutting out
Old Apr 28, 2014 | 05:32 PM
bamax100's Avatar
Default Bayou 220 miss/cutting out
95 Bayou will fire right up but sounds like it's missing, has a "skip" to it.
Checked plug,cleaned carb and installed a new choke with cable.
Fires right up and runs fast.Seems to come in harder you run it but as you throttle down it misses and sounds like its going to cut off as it idles.
Any ideas on what it could be?
Old Apr 28, 2014 | 07:01 PM
ken1988's Avatar
Check the valve lash.
Old Apr 29, 2014 | 08:17 AM
Zrock's Avatar
Super Quad Patrol
Just do what a guy told us to do on one we were selling. Told us the carb over flow had to be routed into the air box and had the rpm up to around 2000. Told us he would adjust it for us but the carb did not have a air/idle screw any ware...LOL
Guess ill have to check the valves never thought of that. have the same thing random miss at idle.
Old Apr 29, 2014 | 05:45 PM
Scott_Tx's Avatar
mine had a little miss but its seemed to clear up with a good carb cleaning.
dont forget to check your float height, always something people forget.
Old Apr 29, 2014 | 06:41 PM
ken1988's Avatar
My brothers 2004 250 Bayou would let out a little pop out the intake at idle (like very 10-15 seconds, it would die out on occasion), and it would pop out the exhaust a lot when you let off the throttle. I cleaned, and tuned the carb (didn't help), checked, and adjusted the valves all the popping went away.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
wendal
Sep 15, 2015 01:50 PM
rcappie4
Sep 9, 2015 07:04 PM
