Electric Start Fail
Old Apr 29, 2014 | 04:56 PM
Richwon4's Avatar
Default Electric Start Fail
Got my bayou from a guy who said the starter solenoid was bad so I put new one on and I get same click click as the old. So the prob was not the solenoid. What is the problem?
Old Apr 29, 2014 | 07:53 PM
Scott_Tx's Avatar
there's a starter relay there also. How's the battery?
Old Apr 29, 2014 | 07:58 PM
Richwon4's Avatar
Default Electric Star Problem
What should battery be cranking and how do I check the relay?
Old Apr 29, 2014 | 08:01 PM
Scott_Tx's Avatar
you've charged the battery up? it should show between 12.5 and 13volts. you'll need a service manual to figure out how to test the relay.
Old Apr 30, 2014 | 02:47 AM
The most common starting fault on all quads is the starter brushes. Put a test lamp between earth and the live terminal on the starter, press the starter button, if the lamp lights and the starter doesn't run, it is the starter at fault.
4xrider
Apr 10, 2017 01:36 PM
Mikes350X
Nov 20, 2000 04:04 PM
rmx251
Sep 10, 2000 11:40 PM
Dom
Aug 3, 2000 08:04 PM
4trax300ex
Jul 29, 2000 11:41 AM
