Removing rear axle
Old Aug 18, 2014 | 07:02 PM
bvolks's Avatar
Default Removing rear axle
I'm getting ready to pull the axles to replace the bearings and seals on my 300 Bayou. Is it as simple as removing the drums and the 4 bolts in the bearing retaining plate and pulling it out? I tried pulling one out of my parts bike today and it wouldn't budge. Is there anything else that needs to be unhooked or do you usually need a slide puller to get them out?
Old Oct 10, 2014 | 01:36 PM
bvolks's Avatar
Here's how I removed mine without any special tools. I removed the drum and the 4 bearing retaining bolts and cover. Then I put the drum back on just enough to get the nut started quite a few threads and slid 2 long 3\8" extensions between the drum and backing plate. As I tightened the nut it pulled the bearing and axle out easily.
When doing the left axle, I had to put the seal onto the axle first and carefully push it into place with the axle part way down the tube because there is a collar that fits on the end of the axle on the inside that is bigger than the hole in the seal. I wish I had taken pictures because I know I'm not explaining it well enough.
It only took an hour and a half to do both sides and a lot of that time was spent cleaning the gear oil off the brake shoes and backing plates.
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Jul 28, 2015 01:58 PM
Bell21
Jul 28, 2015 06:52 AM
Sandman2.0
Jul 21, 2015 09:03 AM
Rider252
Jul 6, 2015 03:37 PM
