Prairie 360 electrical problem ... I think
Old May 28, 2021 | 11:04 PM
B DuB's Avatar
Master of Nothing
Default Bad gas
Originally Posted by ReconBayou
It runs perfect for about a mile. Then it would cough, spit, sputter, backfire and stop running. I can let it sit for a while and it will run perfect for a distance in proportion to how long it would sit. Now at this point I'm sure you are think "it's a fuel supply fool". NOT!!. I took fuel cap vent apart, Blew through the vent tube, checked fuel to carb bowl by opening the carb bowl drain screw and draining a gallon of gas out at a rate fast enough to supply a big block Chevy. I didn't tear the carb down because any problems such as this would act up immediately and forever. Ah ha!!! It must be electrical! I can turbo charge a jet ski, build a 1000 hp small block Chevy, install a supercharger on a 2015 F150, and a bunch of other stuff but I know nothing about electrical. I put a new coil on it ... no help at all. Changed out the ICU. That changed the symptoms but helped not at all. Now it will go the mile and keep on going provided I keep the rpms up. It will do as before if rpms are in the bottom 3rd of rpm range ... exactly where my wife keeps it. OK, now I'm stumped.
It sounds like bad/old gas has ran through the motor and candy coated the valves. When the motor warms up the valves get sticky and make the engine run like poo.
Old Oct 31, 2022 | 05:37 PM
carloscuda's Avatar
I had a similar problem, it was a hot wire (brake Light) doing grown.. I just put some tape and now runs like a champ.
skinnyr6
Aug 25, 2023 02:18 AM
Unzzy66
Jul 11, 2015 10:01 PM
coolguy420
Jul 10, 2015 01:17 AM
coolguy420
Jul 9, 2015 09:54 PM
ranvette
Jul 4, 2015 06:13 PM
