650 belt deflection question
Old Oct 20, 2001 | 12:46 AM
th41004's Avatar
extremelean, I believe this is what happened to me. When appling 12v directly to the servo should I ground the black and power to the red or power to both red and black. Also can I do this with the cover on? Thanks.
Old Oct 20, 2001 | 04:01 AM
extremelean's Avatar
th41004
the 2 wires "to the actuator",BLACK & RED....does not matter which one you hook positive & negative to,Its just a DC motor that will change direction when you change the polarity.
The CVT cover needs to be removed when you do this so you can watch the KEBC forks return to a fully seated position against the inside of the cover.
Good luck & be careful
Old Oct 20, 2001 | 05:31 AM
th41004's Avatar
extremelean, Thanks a bunch for your help, I couldnt figure out what I had done.By the way, will this stop the lights from flashing?
Old Oct 20, 2001 | 04:14 PM
woolfy's Avatar
try it for a test unplug the kebc and make a run.
bigred20653
Oct 2, 2015 10:05 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
stcspiderman
Sep 13, 2015 05:15 PM
Logan Collins
Sep 5, 2015 08:03 PM
