Tires - Hubs - Wheel Spacers!!
Hello:
I wanted to hear from any Mojave riders who have maxxis razr's. How well do they hold up? Do they wear quickly like a lot of people say, and how well did they really work. Also about hubs, which hubs will fit on a mojave to make it possiable for 9 inch rims. And wheels spacers why is it not a good idea to have them in the front. Are they ok in the back.
Hope you can help!
Later
Hope you can help!
Later
i can't help you w/ the wheel spacer question, but i have bandits all the way around. They're 20-10-10. They came with 9 inch ITP rims. I didnt have to get different hubs. My friend has a Suziki quadsport w/ razrs on it. It seems like they've been holding up fairly well. I wanted to get razrs, but i decided to get bandits instead. I'd recommend razrs, they seem like good tires
If you mean 9" tall not wide, then you will need to get Durablue hubs-4x110-I know that James Lucky carries them-haven't seen them anywhere else-but try RM ATV-they are usually cheaper. I just got my Razrs-not too much time on them yet, but so far they seem to be working well. Wheel spacers are hard on bearings and suspension parts because of the leverage they add to the unsprung weight of the tires and wheels. I went with more offset rims-if you are getting rims anyway just get a different offset-spacers cost $70-rims cost the same no matter the offset. For my front I got 6" wide-2" in & 4" out. For the rear I got 9" wide-3" in 6" out and it really widend up my Mojave. I got them from Treadepot.com-that is the only place out of about 5 or 6 that I called that would even try to get those sizes for stock pattern on the Mojave.
Jul 24, 2015 11:57 AM
