Praire 650 - Better suspension??
Old Mar 5, 2002 | 09:09 AM
Ianpraire650's Avatar
I love my praire 650 but wish the front suspension was a bit better. Where we ride, Crooms, FL. there are TONS of whoops on all the trails and the faster i go the front suspension cant keep up and the quad then starts going wherever it want regardless of steering inputs. It either needs a different rebound or compression adjustment, but basically "as is" does not do a very good job for me when the pace increases. Any suggestions for improvements?
Old Mar 5, 2002 | 10:00 AM
kevin_staton's Avatar
Progressive Suspension
It won't change the rebound but the progressive rate spring should make for a better ride.
Old Mar 5, 2002 | 07:48 PM
DustinMinnesota's Avatar
Hi James,
We offer our spring pre load kits for the Prairie which retail for $169 through any local motorcycle shop. The kit consists of 2 springs with our collar adjusters. You can check these kits out on the ATV page of our web site www.progressivesuspension.com. The part number for this kit would be 31-2006.
Thanks
Josh
Forgot to mention this is the email I recieved from Prgressive sorry guys.
Old Mar 5, 2002 | 08:17 PM
RubiconMan500's Avatar
I agree that the front suspension isnt that great on the Prairie to soft.
Old Mar 6, 2002 | 04:25 PM
ROPADOPA's Avatar
hey i have also rode my prarie in the woops at crooms what i figured out after i switched to 27'' mudrunners on douglas wheels the *** end was a little heavier and droped quicker in the whoops so with that mod and leaning back i was able to run wide open on the back stretch of crooms west side going north or south gets a little scary but if you hold on tight sheel do it
Old Mar 12, 2002 | 01:11 AM
tampavii's Avatar
HAs anyone installed these spring on there 650 yet Please post report
Progressive Suspension is pleased to introduce our new front spring/pre-load adjuster kits for selected ATV's equipped with strut suspension (Polaris, Yamaha Grizzly, Kawasaki Prairie). These kits contain a pair of progressive rate springs and a threaded adjuster which will allow the user to adjust the pre-load for different loads and riding conditions (the stock spring setup is nonadjustable).
Front Spring Kit with Pre-load Adjustment Allows easy adjustment of spring pre-load for different loads and varying conditions. Progressive rate springs give better ride and handling over a variety of surfaces.
Available for Polaris ATV's, Kawasaki Prairie 650 and Yamaha Grizzly.
MSRP
$169.95
Robinhood
Dec 26, 2015 10:28 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
Nekolai1
Aug 25, 2015 10:04 PM
Mssarabug
Aug 10, 2015 12:56 PM
