prairie headlight adjustment?
Old Mar 11, 2002 | 05:18 PM
thumpin650's Avatar
I just installed a new headlight lens on my 650. I wanted to make sure that the beams were alligned alright and found that no matter what I did they were out of adjustment. I'm not sure if they're supposed to be like this or not, If someone could check and let me know I's appreciate it. When I shine them against a wall in my garage one is always higher than the other, then when I turn on the high beams the one that was originaly higher than the other becomes lower and visa versa. It's like going from low to high will causes one to shine higher than the other then you switch to high and the opposite happens. Is this normal?
Old Mar 11, 2002 | 05:34 PM
robh's Avatar
The bulb may or may not be seated properly. I also think the bulb needs to be in the housing a certain way too.
Old Mar 11, 2002 | 06:45 PM
thumpin650's Avatar
Sh&%, it just dawned on me. I installed the buld upside down. Learn from my mistakes. I'd suggest marking it because the housing is circular and doesn't say "top" anywhere.--oh well, another hour....
Also don't use Goof Off on headlight lenses to remove the sticker residue.
hueby
Nov 6, 2015 11:34 AM
PrairieDog126
Sep 16, 2015 01:33 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
PrairieDog126
Sep 12, 2015 05:23 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
