HOW FAST WILL YOUR PRARIE 650 GO?
Old 04-02-2002, 03:30 PM
roadrashron's Avatar
I had mine at 69mph, on the road, with alot of room. It got to 63 or so pretty fast but then it needed some room to top out. I also hit 66 in 4x4 racing a banshee, I beat it. The field was rather wet and the banshee spun a little too much. It is bone stock, I weigh about 175lbs. This thing rocks. [img]i/expressions/face-icon-small-happy.gif[/img]
Old 04-02-2002, 05:19 PM
kingmort's Avatar
98KM/hr almost all the time, hardpack gravel
Old 04-02-2002, 05:24 PM
krabill's Avatar
I tucked one in my draft for about a mile of paved road, he was doing 68 constant and he couldnt get it faster.
91 TRX350X
85 ATC250R shattered piston, damn...
86 ATC200X
Old 04-02-2002, 07:43 PM
ctebbe's Avatar
I've had mine up to 65mph on a paved road. Gets to 60 quick though.
  #15
Old 04-02-2002, 08:02 PM
DUstanko's Avatar
68 mph here according to the 650 speedometer right after my break-in period. Mode was 2X4 high gear. I rode on blacktop with stock tires. I have rack extenders on which may or may not affect wind resistance. I am 6'2" 200 lbs. The speedometer SLOWLY climbed from 62 to 68 mph.
Daryn
  #16
Old 04-02-2002, 08:12 PM
tampavii's Avatar
got it up to 64 with stock tires
Now with 26 inch mudrunner will hit 58 mph
Me 6ft 210lbs
  #17
Old 04-02-2002, 08:44 PM
Area51's Avatar
On a very hard pack dirt road, with very slight curves, I was able to reach 67 mph. I then turned around and road it back the opposite direction on the same stretch of road and hit 66 mph. I wanted to check the speed in both directions to get an average speed in case the road was not perfectly level. The road had a pretty long stretch with only slight curves in it, and then became too curvy to keep it at full throttle. But during the Simi straight length, I was able to obtain the above-mentioned speeds. I live in Las Vegas NV, and the elevation is around 2,300 feet. The temp was about 65 degrees F. I only weigh 145 lbs so that may help with me being able to reach these speeds. I wish I had several miles of straight flat road, to see if it would go even faster! My 650 is completely stock right down to the Dunlop tires, I had about 11 hours on it at the time, right after the first 10 hour service. I have since removed my racks, which lightens the 650 up by 22 lbs. I don't know if that will make a difference, but it sure cant hurt and I don't haul anything on the racks anyway. I think it makes the 650 look allot sportier. I got the idea after seeing Mike Penlands GNCC Prairie 650!
  #18
Old 04-02-2002, 10:15 PM
CherokeeKid's Avatar
66 MPH. Stock....
  #19
Old 04-02-2002, 10:24 PM
cajun650's Avatar
105 km/h in 4x4 high on gravel road.stock and 190 lbs.
  #20
Old 04-02-2002, 11:18 PM
scootdog's Avatar
well, after repacking the parachute and tightening the blower belt,
i laid down a 63 mile an hour run with a tailwind and my fat **** of 215lbs.
Quick Reply: HOW FAST WILL YOUR PRARIE 650 GO?
