Recoil back-up start for a 650 PROBLEM!
Old Apr 15, 2002 | 09:06 AM
monteSS's Avatar
Has any one tried to pull there recoil start cord yet? I tried the other day and it took 20 min for it to go back in. Has any one experienced this? I am going to call the dealer and take it back in for them to look at. Just wondering if any one has seen this yet?
Old Apr 15, 2002 | 11:23 AM
trx450's Avatar
Never tried mine! Guess I should...........
Old Apr 15, 2002 | 11:58 AM
monteSS's Avatar
Thats what happened to me a buddy asked how hard they were to pull and I said I don't know and gave it a yank and out it stayed. I had to tug and play with it for about 20 mins to get it back in. Its supposed to be like a lawn mower and go right back in RIGHT???
Old Apr 15, 2002 | 12:01 PM
trx450's Avatar
Yep it is supposed to recoil, right back in the the housing.
Old Apr 15, 2002 | 12:07 PM
monteSS's Avatar
Even tried starting it to see if that would help loosen it up and go in easier but to no avail. I will be calling the dealer and taking it in. Just wanted others to check it before they need it. Its hard pushing a 600+lbs maschine home. You can't push start them!
Old Apr 15, 2002 | 12:14 PM
TrailHog's Avatar
I had the same problem, it is not water tight. I pulled it back out after I finally got it back in. I sprayed silicon spray on the rope and inside the cover thru the rope hole. It worked like brand new again. I guess dirt and water had gotten in there. There should be a way to water and dust proof it. I now always pull it out a few times after crank up to keep it freed up.
Old Apr 15, 2002 | 12:19 PM
monteSS's Avatar
I will try spraying something down there also then and see if that does any thing I didn't want to try that and the dealer say I screwed it up and I was on my own. I'll try that when I get home tonight and let it sit for a while. Thanks for the info. Something else to add to the list and keep a watch on and take care of for normal maintanence.
Old Apr 15, 2002 | 12:20 PM
prairie633's Avatar
I've heard of some people starting them by rolling down a hill or by being pulled. I will test this next time I am out.
Old Apr 15, 2002 | 12:23 PM
TrailHog's Avatar
I tried rolling it down a hill, but I could hear the KEBS working on the belt, so it crawled down the hill and never cranked.
Old Apr 15, 2002 | 01:40 PM
kingmort's Avatar
You can waterproof the pull start.Just fill the end of the handle with silicon and put it back in place.Then you just leave it alone until you need it.
