Prairie 12V outlet?
Old Apr 25, 2002 | 11:16 PM
Lurch77's Avatar
It is on the frame above the exhaust, just behind the fender bracket. Has a cover on it.
Old Aug 12, 2002 | 11:59 AM
Bram's Avatar
Where is the fuse located at for the 12v outlet?
Old Aug 12, 2002 | 12:41 PM
Dextreme's Avatar
<< Where is the fuse located at for the 12v outlet? >>
Under the seat.
Chuckybrown's Avatar
Under the seat in the fusebox.
Chucky
Old Aug 12, 2002 | 12:43 PM
  #15
Bram's Avatar
Which one?
Old Aug 12, 2002 | 12:50 PM
  #16
Dextreme's Avatar
Plug something in and start yanking fuses. Only takes a minute to figure out which one it is.
Old Aug 12, 2002 | 12:56 PM
  #17
Bram's Avatar
That's the problem it does not work! I thought maybe someone might know exactly which fuse it was, and it's location because all of them are good, no burnouts.
Old Aug 12, 2002 | 01:09 PM
  #18
Check the fuse in your plug on the end of your compressor cord. Chances are you blew that puppy instead.
Chucky
Old Aug 12, 2002 | 01:12 PM
  #19
trx450's Avatar
BRAM-- Look at the owner's manual, it should show you &quot;who's who&quot; in the fuse box.
Old Aug 12, 2002 | 08:05 PM
  #20
bigddoney's Avatar
check under front plastic there is a quick connect. on mine it wasnt put together.i never used it just found when it when wiring my plow lift.
