650 won't start in N
Old Apr 24, 2002 | 03:28 AM
650DAD's Avatar
HI i'm having a little problem my 650 used to start in neutral by just hitting the starter button now you have to pull in on the brake to get it started any help would be apperciated
Old Apr 24, 2002 | 03:37 AM
coolinthewoods's Avatar
Is your shifter in nuetrel? If so try moving it around when hitting the botton. Your shifter might be out of adjument.
Old Apr 24, 2002 | 06:16 AM
scootdog's Avatar
maybe the neutral saftey switch is bad....
Old Apr 24, 2002 | 08:47 AM
trx450's Avatar
650DAD-- You have a PM.
Old Apr 24, 2002 | 12:24 PM
650DAD's Avatar
I have messed with moving the shifter around,I have checked all the fuses.It will start in nuetral but I have to pull in on the brake.Where would a nuetral switch be found.
Old Apr 24, 2002 | 11:26 PM
I think it is below the shifter I'll check for it tonight.
Old Apr 25, 2002 | 07:54 AM
trx450's Avatar
HEY 650 DAD--- You have a private message!
You might want to buy a factory service manual for the bike, they cost @$30.00 at the dealers. The manual will have a troubleshooting flow-chart for the neutral safety switch circuit. Sounds like the shifter is way out of adjustment.
Old Apr 26, 2002 | 11:26 AM
kawlaris's Avatar
Hey 650Dad
I had the same problem with mine. I had the dealer fix it under warranty. It is a bad relay under the seat. I do not have the part # or any information but I did see what they replaced. I could probably get more information if you need it.
kawlaris
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
