NYROC, I got a question for ya.
Old Apr 28, 2002 | 12:16 PM
mastrblastr's Avatar
I have been reading a lot of these posts and see that you have modded your 650 quite a bit. I would like to replace my stock aircleaner with a K&N filter. Do I have to rejet my carbs when I replace the filter? I know it will be breathing WAY deeper with the K&N on there.
Old Apr 28, 2002 | 11:13 PM
nyroc's Avatar
You may be ok, but it depends. A friend of mine put a k&n on and did not rejet.
You really need to modify the airbox if you go to the trouble to put a filter in. Uni vents in top are probably the easiest solution that is no detrimental.
Old Apr 29, 2002 | 01:30 AM
Encore454's Avatar
A friend of mine put a K&N on his 650 without any other modifications.
It has caused his engine to run much leaner which has also caused it to run hotter. His fan is on almost all of the time. He has ordered a jet kit to fix the problem. Has anyone else had this happen?
Old Apr 29, 2002 | 02:12 AM
Thanks for the responses guys. Carbs are not my thing so maybe I will just get a stock cleaner. You never know. I might get brave and go for it with a K&N powerkit!!
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
