Dynojet help please
I'm installing my Dynojet kit now and I was wandering if I am supposed to use 2 E-clips on each needle? The instructions only show the E-clip then 2 washers but the package came with 4 E-clips.
Any advice would be appreciated.
Just one E-clip per needle. When you get the needle back in and the other parts that go on top, put the spring in the slide and compress it. Then take your finger and try lightly pushing on the tip of the needle see if it wigles around or has some play in it. If thier is I usualy stick the other E-clip above the first one, this gives a positive hold on that needle.
But 99.9 percent of the time 1 E-clip with 2 washers above it is good. But keep in mind what I just said, it's easier than it looks to loose one of those washers.
CG400exMaster
Sep 25, 2000 12:17 PM
