KLR Black Box on Mojave
Old May 13, 2002 | 10:57 AM
mojaveman1's Avatar
I was wondering where i could get a klr250 black box
Was the motor on the klr the same as the mo motor
Old May 13, 2002 | 02:24 PM
AlkyBurninX's Avatar
You can find a KLR box at your Kawi dealer or check around online for a dirtbike salvage yard. I have bought parts from a place called Cycle Salvage in CT. Their phone is 203-993-1600. They deal in street bike only, but since the KLR is a dual sport, they might have a box. Used is usually half of new. Although I am not famialar with the wiring on the Mojave/KLR, I had to swap a couple of wires when I put a 300ex box on my 250x. You might have to do the same if the mojave has a reverse rev limiter (since the KLR doesn't have reverse). You might be better off to call someone like Sparks Racing. They have high-rev boxes for many different models.
Old May 13, 2002 | 04:53 PM
Mxracer98's Avatar
You can order the klr250 black box from any Kawasaki dealer. Its pretty pricey. I think mine was $250.
Old May 13, 2002 | 05:02 PM
mojaveman1's Avatar
what does it give you besides a higher rev
and how high does it rev i think the stock is like 11500
Old May 13, 2002 | 05:41 PM
Mxracer98's Avatar
Actually is eliminates the rev limiter. I think stock is like 8500-9000 rpm
Old May 13, 2002 | 05:42 PM
mojavekid13's Avatar
MXracer is right it is around 8500rpm not 11500 the klr one does put it to about that though
Old May 14, 2002 | 09:49 AM
mojaveaddict's Avatar
It's much cheaper to just send your mo box to Mickey at FST and for 80 dollars you get the rev limiter removed. I think the timing on the klr box is a little more aggressive but not enough to make a real difference and may cause detenation on a mo using pump gas.
Old May 14, 2002 | 10:04 AM
sickmojave's Avatar
I know that when I got my cams from web they said to change the black box to the KLR box.I never get in to the rev.limiter anyway so what would this help?
Old May 14, 2002 | 05:15 PM
If you have the big web cam and never hit the stock rev limiter you are short shifting before the best part of the power band is used up. The rev limiter will come in while it is still pulling hard.
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
