Prairie 650 Plastics/Factory Stickers
Old 05-15-2002, 12:05 PM
Parker650's Avatar
Anyone know if replacement fairings (plastic - all the way around the entire quad, fenders, everything) is available for the 650? How much? Also, is there a factory sticker kit available for original factory 650 stickers? Just wondering, getting some ideas about changing some things around and want to see if replacement parts are available should I do this and it doesn't work out. Thanks
Old 05-15-2002, 12:27 PM
monteSS's Avatar
Check out this post
Who has cracked or broken fenders on there Prairie 650?
Area51 replaced his he would be the guy to talk to he also list the price in that thread they aren't cheap!!!!
Old 05-15-2002, 12:47 PM
nyroc's Avatar
I think he just ordered them straight from the dealer. You can see part numbers for all the plastic and the decals on www.buykawasaki.com.
I think Area51 spent $400 on plastic. His quad is shaved, no racks. Looks pretty neat.
I will consider spending $400 on plastic when it is available in camo.
Old 05-15-2002, 06:41 PM
Cose's Avatar
Hi Monte, I have 3 bolt holes where the plastic was torn. I put an oversize bolt and washer and it is doing quite well.Dont look bad either asfter I painted them black.....
Old 05-15-2002, 09:54 PM
DustinMinnesota's Avatar
Me Changing to camo too no stickers
Old 05-16-2002, 06:05 AM
monteSS's Avatar
Good to here a bolt and washer are a lot cheper than new plastic. Did you end up mounting your switch like mine then.
Old 05-16-2002, 09:51 AM
trx450's Avatar
Anyone know how much the "wimpy" fender flares/extensions are? I've ripped a frt. one already! CHEAP DAMNED PLASTIC!!!!!!!!!!!!!!!!!1
Old 05-16-2002, 10:34 AM
nyroc's Avatar
I use goop to fix a rip in the flares. I keep it all on the inside, and use spent dryer sheets to reinforce it (and keep it from running off when drying). I have hit trees with the same fender, which bend the flare inside out, and it held up fine.
Doesn't look as good as new, but I don't think it is reasonable to replace them every time they crack.
Old 05-16-2002, 10:45 AM
trx450's Avatar
nyroc--- $hit, If I replaced the flare every time it cracked, I'd be bankrupt in 3 months! I may try your fix next time.
Old 05-16-2002, 11:32 AM
Parker650's Avatar
AREA51:
Do you still have your plastics for sale? If so let me know...thanks
Parker
Quick Reply: Prairie 650 Plastics/Factory Stickers
