air filter
Old Jul 22, 2002 | 08:34 PM
packardbell15's Avatar
what should i use to clean the air filter with on my prairie 650 besides solvents.
it needs to work good and make the air filter last
the air filter is the stock one
Old Jul 23, 2002 | 11:56 AM
Lightninn's Avatar
Solvents such as what -- gas?!?!? Never clean your foam filter with solvents such as gas. Gasoline will attack the foam rubber and cause it to degrade and become brittle and fall apart. Also, gasoline (or equivalent) will break down the cement holding the foam filter parts together. I use PJ1 foam filter cleaner and PJ1 foam filter oil (not engine oil!!) to service all foam filters. These come in spray cans and are around $5-$8/can. You can usually find them at your local quad dealership or you can order them from mail order companies like Dinnis Kirk, Magic Racing, James Lucky ATV, etc.... Remember, when washing a filter, don't wring out the filter out like it's a dishrag. A foam filter will tear if you aren't careful. Just sling the filter to rid it of excess water and let it sit overnight to completely dry before oiling.
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
black798
Sep 9, 2015 07:42 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
