Dynojet install difficulty?
I recieved the Dynojet kit last night and I immediatly noticed a lack of detailed instructions.
I guess they expect you to have done this before or have the service manual.
Is this total project very difficult? How long does the install take?
I noticed some of you guys are using jets that are different than they recommend. I would prefer to only do this once, (not change jets after).
That doesn't sound to bad I ride at up to 2300 feet and use the 128 and 132 with it on the second notch and since you are higher it should run rich so you should go with a smaller jet size for my elevation it calls for it in the 5th notch but every one runs in the 4th betterresponce on te throttle. Teh jets are easy to change maybe fifteen minutes teh needles is what you have to take every thing apart to get at. biggest thing is just make sure you have good ends on the screw drivers!!!!
jrooker6
Apr 23, 2016 07:36 PM
