Sticking in gears in Lakota?
Old Aug 19, 2002 | 04:03 PM
WheelinMan's Avatar
My Lakota for some reason wont shift up into Reverse Neutral or 1st very easily,u have to rock it HARD or touch the throttle and shift before it gets wound back down...is this because its BRAND New and the gears arent worn down yet so its catching? or what should i do if nething??
Nething would help Thanx a lot...i kno ive been posting a lot but im just really curious
Also is there nething important id have to get to under the seat? because its REALLY hard to get it off!!!!!!
Old Aug 19, 2002 | 04:12 PM
DaLakotaMaster's Avatar
I have a 2002 Lakota sport and i have problems too so one day i got pissed off at it and i broke my shifter so i ordered a new one maybe that will do the trick
Old Aug 19, 2002 | 04:24 PM
WheelinMan's Avatar
Hahaha that could do it..i take it u havent got the new shifter yet? tell me what happens
if u cant get ahold of me on here than e-mail me burgabouy@yahoo.com
Old Aug 19, 2002 | 05:08 PM
gaff's Avatar
Your clutches need adjusted, thats all. Adjust your clutch and it will be fine.
Old Aug 19, 2002 | 05:58 PM
WheelinMan's Avatar
how?
Old Aug 19, 2002 | 09:07 PM
gaff's Avatar
Take the black plastic piece off by your right ankle, see the slotted bolt with a lock nut.
Loosen the lock nut, Hold it in place. With the lock nut held in place turn the slotted bolt in untill it stops. Then back it out untill you just feel slight resistence. Tighten the lock nut down and your done.
Old Aug 19, 2002 | 09:13 PM
WheelinMan's Avatar
ok sounds simple enuff..thanx
Old Aug 19, 2002 | 09:52 PM
dangerousrider400's Avatar
the reason that the seat is hard to come off is because IT DOESNT COME OFF!!! you have to remove 4 nuts underneath the seat towards the back in order to remove it. and no, there isnt anything important under there.
Old Aug 19, 2002 | 09:53 PM
WheelinMan's Avatar
Yeah thats what i figured but i was wondering about the carbuerator(sp) and stuff like that but i guess u can get to it from the side
thanx
Old Aug 20, 2002 | 03:48 AM
antix's Avatar
to get the seat off is pretty easy there is 2 bolts on the grab bar an 2 rubber hooks you just undo those and the seat along with the whole rear plastick comes off. that makes it alot easier to work on
