Need new tires , Help me decide - details inside
After last week's fiasco with the Dunlops (see my post below), I have decided to get new rubber for the 650.
I mostly ride hardpack trails, woods and fields. Very little mud and some rock. I also will be using these tires when I plow snow. I am rarely in 4wd (only over obstacles, or up hills) I am looking for a good, smooth-riding all around tire, with excellent handling characteristics.
I will eventually want to get a set of "ITP Holeshot ATR" on aluminum rims, but for now, I want to go with a stock size 6-ply tire on the stock rims.
Here are my choices:
$180 - $200 Range
1. Kenda Bear Claws
2. GBC Dirt Devils
3. GBC Gators
$250 Range:
ITP 589 M/S
ITP Blackwater
I don't mind spending the $$$ on the ITPs', but they seem more suited for mud. Right now, I am leaning toward the Dirt Devils or the Bear Claws.
What do you guys think?
BTW I am putting the Warn A2500 multi-mount on this weekend - I'll let you guys know how it goes.
$180 - $200 Range
1. Kenda Bear Claws
2. GBC Dirt Devils
3. GBC Gators
$250 Range:
ITP 589 M/S
ITP Blackwater
Go with the Dirt Devils, they are perfect for the uses you described. However you will want to go with a 26 or 27 inch tire due to the tread depth and profile of the DD. 25s are really between 23 and 24 inches and only have about a half inch of tread depth compared to 1.25 inches on the XTs (26" and larger).
HI GUY'S:
I just ordered a set of 26-9-12,and 26-12-12 Kenda bear claws...I read alot about tires before making my decision. I feel I made a very informed choice. Look at the terrain that you mostly will be riding on and then look at the choices. For my money the Kendas seemed to fit best. I am trembling like a Bunny in anticipation for my new tires.
PS: Master "NYROC" recommends the Kendas Highly...and he ain't no dummy.
ROB
ROB
Again, Thanks for the quick replys.
It seems like the two tires that I was leaning toward are the front runners(Dirt Devils, Bear Claws).
However, I was going to go with stock sizes. It seems that most everyone is going with 26"-28" (and reccomending) over the 25". I don't need the extra ground clearance, so what is the advantage? Muddhound stated that the Dirt Devil 25" are really between 23 and 24 inches and only have about a half inch of tread depth, so that may be a reason, but what about the Bear Claws?
Also, what would the full front/rear tire sizes be for 26" or 27" tires on stock rims?
example fr:25-8-12 rr:25-10-12
Thanks.
Thanks.
I think everyone goes taller because they can.
And.....some aftermarket tires are actually shorter than stock tires. I got 26" 589 M/S's because when we put a 25" tire up next to the stock tire, it was actually shorter. So, I went with 26" tires because I didn't want to GIVE UP ground clearance!
I went with 26X9X12 on front, and 26X12X12 on back. Pics link in my signature line if you want to see what those size tires look like.
Chucky
Chucky
I have been wondering these same questions. Why are most of you riding 26 when a few of you are using 27? If both will fit the stock rims, than why wouldn't everyone be riding the 27s to get another .5 inches of ground clearance? I have read some that said that the bigger they are, the less power you will have. Is that the main reason to go with 26s. Thanks for your answers.
