Sprokets and changing MPH
Old Oct 19, 2002 | 10:38 PM
rx7351w's Avatar
Default Sprokets and changing MPH
IF I put an 11 tooth front sproket on my mojave how much top speed will I loose? I think stock it is 12/42.
Thanks
Chad
Old Oct 20, 2002 | 12:24 AM
mojavekid13's Avatar
Stock is 12/43, and u will lose ALOT of speed! i mean alot! i went up to a 13/41 with 20incher razers! and it climbs hills way better now!
Old Oct 20, 2002 | 12:38 AM
rx7351w's Avatar
I like it better with the 11 on it. 5th gear is more like 4th gear now but I can climb up rocks slower. I have a speedometer on it but I dont think I have it calibrated right. If it is calibrated right it's top speed is now 45. I was trying to see what it should be so I could see if I have the speedo calibrated
Old Oct 20, 2002 | 12:10 PM
albaBANSHE's Avatar
if you put a small sprocket on the rear it willl gain your lost speed and if you have over 20'' tires that losses speed 18'' or 20'' tires gain speed
Old Oct 22, 2002 | 01:53 PM
Youe way wrong about that! If u have 22'' or say 21! u will be faster then 20 or 18! The bigger the the tire the FASTER u go! The smaller the more slower, but more bottom end ya get!
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
