Lakota needs new tires ??????????
Please help me decide! Ride alot in the woods (do not want to lose ground clearance). Ride alot on home-made track with jumps. I want a tire with a smooth ride also. Any opinions on style and size would be appreicated.
If you want to keep the ground clearance I would stick to the stock size. However, I think the 20" maybe a better choice. As far as which tire, I would look real closely at the Razr's. These will be my next tires.
Right around an inch. 20" are much lighter. Less rotating mass allows the engine to apply more power. 20" will also give you slightly better acceleration being a smaller diameter. Although, you may lose a little bit of top speed. And, to top it all off, 20" will give you a little better handling in the corners.
Sep 30, 2015 01:37 AM
