carb adjustment
Has anyone adjusted their idle mixture screws on a 03 650? Where are they at on the carbs and what is the best way to get to them? And how many turns out should they be? Also what is a good price for a kawasaki service manual?
Adjusting the idle screws helps with intake backfire and helps it start a little eaiser. They are located on the right side, one on each carb. Just use a small flat screwdriver. 3 turns out usually does the trick.
Ironhead
Try this for setting your carbs.
Turn in the screw untill the motor runs rough take note at position of turns out from bottom eg. 2 1/4 turns. Next turn out the mixture screw untill the motor wants to run fast almost takes off, take note at number of turns out from bottom eg 3 1/2 turns out. Next turn in the screw to half way between the two and you should be okay eg. almost 3 turns or 2 7/8 turns out. Repeat this for both cylinders. From this setting you can vary it by 1/8 of a turn untill you are totally satisfied although I have found it doesn't vary much only say 3/4 of a turn at most either way
GregM
Mar 6, 2018 06:53 AM
