Lift/Jack points for the p650?
Old Feb 4, 2003 | 12:15 PM
Lightman's Avatar
Default Lift/Jack points for the p650?
Where do people lift/jack and put jackstands on their prairies? I want to take all the wheels off and go get the tires changed. Didn't see anything in the manual about lift points..... Any tips appreciated, thanks.
Old Feb 4, 2003 | 12:21 PM
nyroc's Avatar
Almost everywhere is a jack point. Anywhere under the frame or susp is good. I would avoid anything that makes a ding in the rear axle. The rear diff is ok, as is the front skid plate. The main skid may be ok, but I would use a place where the frame is.
Old Feb 4, 2003 | 12:37 PM
monteSS's Avatar
Underneath!!!
It depends on what you are planning on lifting it with. Are you using a ATV / motorcycle jack? They have them at Sam's for like 90 bucks. If so just put it in the center and jack. If you are using a regular jack you will need jack stand ( I would use the jack stand in the front on the frame and the rear you may be able to leave the jack under it if you won't be leaving it to long. If not put a rag on the jacks then you could put it under your axles toward the out side.
Old Feb 4, 2003 | 03:01 PM
EasterEgg's Avatar
I lifted mine by the trailer hitch and put jack stands under each side of the axle then I put a piece of wood under the front skid and jacked there. That got all 4 wheels off the ground at once. HTH
ReconBayou
Oct 31, 2022 05:37 PM
Customer Service #1
May 15, 2020 08:46 AM
EIF
Apr 20, 2017 07:15 PM
bigred20653
Oct 2, 2015 10:05 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
