runing lean.....bad for engine
Old Mar 23, 2003 | 07:37 PM
prairievenom's Avatar
Default runing lean.....bad for engine
is running lean bad for your engine, if so how bad is it[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 23, 2003 | 07:44 PM
Scotia650's Avatar
Lean is definately not good. If your too lean, you could be looking at cylinder damage or seisure.
Are you lean on bottom or top? Bottom would cause poor starting and takeoff while extended lean runs on top end could cause engine problems.
Be careful. [img]i/expressions/face-icon-small-frown.gif[/img]
Old Mar 23, 2003 | 07:48 PM
Scotts88's Avatar
lean will make more power then rich..but if you go TOO lean, then you run the risk of overheating and damaging the motor!
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Cummins Driver
Sep 11, 2019 01:22 PM
austinwhitton
Aug 11, 2015 06:21 PM
Jul 30, 2015 09:39 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
