Speedo Correction
Old Apr 5, 2003 | 10:07 PM
BCLINEHAND's Avatar
Default Speedo Correction
I have gone from stock 25" tires to 27" Mudlites Does anyone knw the formula for figuring out the true reading on the speedo
Thanks
Old Apr 5, 2003 | 10:56 PM
Coyotechaser's Avatar
Measure the exact center height of the tire with the sensor. Multiply the height by 25.4 to convert to millimeters. Then take that number and multiply by 3.1416. This should be the number you enter. If you need to convert back to inches then divide the last number by 1.61. I don't need to convert back to inches with my speedo but some require it. Hope this helps.
Old Apr 6, 2003 | 07:33 AM
BCLINEHAND's Avatar
I think I have it worked out but I may be wrong as it is kinda drunk out tonite
27" tire is approx 8% bigger in circumfrence so speedo should be out by the same gives me a top speed of approx 100 Kmh
speedbuff
13
Nov 11, 2020 10:16 AM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
2many2ride
Sep 27, 2015 04:35 AM
black_thunder
Sep 20, 2015 10:21 PM
