P650 Carbs .... act like choke is on sometimes?
Old Apr 12, 2003 | 11:55 PM
Vforcer's Avatar
Default P650 Carbs .... act like choke is on sometimes?
Could use some help he Guys ....
I have noticed that sometimes my P650 acts like the choke is on .... this only seems to happen after trail riding
for two hours or so. Won't hardly idle .... black smoke from exhaust like choke on .... ????
( I have cleaned the air filter .... everything looks ok ?? )
???????? thanks
Old Apr 13, 2003 | 12:00 AM
mastrblastr's Avatar
The 2002 P650 choke springs are notoriously crappy. Replace them with choke springs out of a '94 KLR 650 and your problem will be solved. The part number for the KLR springs is 92081-1720. They are about 1/4 inch longer than the stockers and are way stiffer. Smartens the chokes up right quick. Remember to order 2.
Old Apr 13, 2003 | 07:10 AM
Vforcer's Avatar
Are the springs independant in some way from the cable ???
Because of how it acts, I kept checking the choke cable **** to make sure it was in the off possition ??
Old Apr 13, 2003 | 11:16 AM
There is a splitter assembly on your choke cable that allows 2 cables to come off your main choke cable. The 2 plunger springs are located at the carb end of your choke cables. What happens is that even though you push your choke to the off position, the springs don't have enough "spring" in them to push the plungers all the way in, which is the off position. Once you put in those new springs, that problem is cured.
Old Apr 13, 2003 | 02:14 PM
Vforcer's Avatar
This is one of the things I most appricate about this forum .... good people giving
good advise to help others. Thanks for taking time to help me Guys
I will install the new springs before the next ride.
( this would most likely explain why I only get about 35 miles per tank of fuel !!)
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
ghost civic
Jul 27, 2015 03:15 AM
ghost civic
Jul 20, 2015 12:36 PM
timster911
Jul 13, 2015 01:57 PM
