KFX700 Yoshimura Exhaust(good info)
Old 04-18-2003 | 04:36 PM
Force's Avatar
Default KFX700 Yoshimura Exhaust(good info)
Pro Rider See I want mine to look stock and make people wander how this thing can be so fast and be stock. It will look stock. Pipes give it away for mod. Clutching, CDI, and carb work will be my goal and to be able to eat up V-FORCES that have pipes.
Old 04-21-2003 | 12:42 PM
XC800's Avatar
Force, you are correct.
I have had years of clutch tuning experiance and the bottom line is, there is no sense making great HP at the crank if the clutch is not delivering it. Lots of unused HP can be gained by a properly dialed in clutch. BUT if you have the clutch dialed in AND a set of good pipes, you are that much better off!!. A power curve with peak RPM/HP is required as well as a good tach to ensure you motor goes to the power peak and sits there through all speeds.
Old 04-21-2003 | 01:21 PM
SHOTGUN's Avatar
If the vforce is set up like the p650, there is more speed and HP to be gained from the clutch than any other mod.
Old 04-21-2003 | 01:38 PM
OrangeCrusher's Avatar
Once I purchase the CDI/carb kit/air filter, is there a good shop around the Washington/Oregon area that I can take my V t o and have the clutching and carb tuned in for optimal performance?
Mike
  #15
Old 04-21-2003 | 02:14 PM
NYVForce's Avatar
Update, The TRS Titanium exhaust is now available from yoshi the Dual exhaust is $950.00, they have not dynoed the exhaust because of the tranny.
  #16
Old 04-21-2003 | 03:02 PM
KevinM's Avatar
I don't know if I can justify $1000 for an exhaust when I can get the HMF for $500 and then spend $500 on a bigger set of carbs or bigger cams or higher comp. pistons. I'm a big Yoshi fan, but unless they're claiming in the vicinity of 15HP, I'm going to have to pass.
Quad Pics
  #17
Old 04-21-2003 | 04:37 PM
mxk24's Avatar
Wow a 1,000 and I have'nt even seen a picture of them yet. I think I'll have to wait awhile more and see if someone else has something.
  #18
Old 04-21-2003 | 09:24 PM
mtecate4g's Avatar
They also are releasing a stainless comp series for abround $700. Same exhaust just stainless head pipes instead of titanium.
  #19
Old 04-22-2003 | 01:53 AM
riverrat's Avatar
I told myself I'd hold out for the Yoshi duals. Today I called and they quoted me $825 for the stainless and $950 for the titanium. Major bummer!... too much for me.
I called Pro Circuit also. They would not give me any pricing. I was told they would have production ready for sales in about two weeks.
So far the HMF at $500 isn't looking too bad.
  #20
Old 04-22-2003 | 02:27 AM
RockTonka's Avatar
I hate to say it but,,I kinda like the quite rumble the 700s got going on. Doesn't FMF make a Q series for this? I've also got a warrior w/ a old DG on it, I can't hardly stand to be around it now. Are there decent semi-quiet options out there?
Quick Reply: KFX700 Yoshimura Exhaust(good info)
