Electrical Problem
Hi,
I have a 250cc Gio Bad Boy, started the bike up the other day and when I pulled the shifter into reverse a pin sheared popping the bike back out of reverse; the bike stalled, when I tried the ignition again a puff of smoke came out of the front cowling. I pulled the front body panel and sniffed the smoke to it's source. Sure enough a small 2'x1x1" block that looks just like a CDI except the plug is completely wrong.
What is this thing? Anybody?
And where could I get a replacement.
I love my little Gio 250, I've had to make some modifications due to my locale and lack of access to parts, but I can always get the thing running, it totally suits my needs and, for the money you can't beat it.
Thanks folks
Thanks folks
How many pins on this black box? What are their colors?
If you unplug this device, does the quad starter turn? Does it start? Assuming the engine starts and runs, what is the battery voltage measured right on the battery terminals with the engine running at a fast clip and the headlights off?
Thanks for getting back LE,
It's an 8 pin male plug. The starter turns but the bike won't start. I've been looking through the parts book tonight and I can't find what this thing is but going over the diagram for the electical system and there is parts on there I can't account, maybe you'd recognize it, "Reverse controller" it has 8 wires running to it. This thing looks like a stock part, mass manufactured, if I could find out what it is I could search for the right kind.
Thanks for your help
First off the wire colors
Green blue Blue red, Yellow white
Black white Red white
Black Green Green black
I don’t believe I’m getting spark now, I haven’t had to test it before so I pulled some info from the net on how to test for spark, and I used this technique, let me know if this sounds right. I pulled the spark plug then put it back on the wire. I held the threaded end against metal parts of the frame and the engine while I turned it over hoping to see a spark. No spark.
Does it sound like I did the test right? Does this mean that this block is a part of the ignition coil?
Thanks again
Thanks again
You did the spark test correctly.
I don't recognize the wire colors or anything about this mystery block. I also don't know if it has anything to do with the ignition system.
Does your CDI look like this?
Do you have a wire on the kill switch connection?
Unplug the CDI. Measure DC voltage on the AC power pin to ground when the ignition is on. Do you have 12 volts? If not, then measure the AC voltage (200 volt scale) on the same pin while cranking the engine. Do you measure AC voltage in the range of 35 to 80 volts AC?
Is there any way you could fax the wiring diagram to me?
ranvette
Jul 4, 2015 06:13 PM
