LT 50 Mods?
Old Jun 15, 2005 | 01:48 AM
sec42credits's Avatar
Default LT 50 Mods?
Can you give me a little detail on how to install the K&N Filter. The current air filter doesn't seem to do anything. What improvements will the K&N filter do for the quad.
Old Jun 16, 2005 | 12:28 AM
lt502000's Avatar
Default LT 50 Mods?
Well the filter will really increase the top end mine seems to just keep building power on the top. I think it makes it rev at least 750 rpm more than stock. But this filter should not be used unless you have a pipe and also have at least a 65 main jet . But with the combo of the three you'll be very happy.
(Filter had the best power increase of all mods.)
The filter From K@N part#RU-0200 is a universal filter that is sold by the dim. of the filter its self.
so to make it work you have to remove the whole filter assembly. You need to cut the part that screws to the carb. right before it opens up to the circle. You should be left with a oval that is 1 inch wide by 2 inch high then you slide the K@N over that oval and tighten the clamp. the filter should almost look like it is right on the carb. You might have to remove the oil injector to im not sure I put the filter on after i removed the injector sys.
Old Jun 18, 2005 | 05:58 PM
Default LT 50 Mods?
The rider of the quad is 5 years old. If I replace the filter only will this improve the performance.
Old Jun 19, 2005 | 12:11 AM
lt502000's Avatar
Default LT 50 Mods?
the quad will run way to lean unless you change the main jet to get more fuel. you cant add air if you dont add fuel. Then if you do that you will at least take the sparkarrestor off the stock pipe. if you have the cash I would get all three. My four year old wouldnt even ride this thing If I put it back to stock he loves the power. so i think your five year old would like it to.
Old Jun 30, 2005 | 02:21 PM
  #15
medicallen's Avatar
Default LT 50 Mods?
hey lt, how are those nerf's for the lt50 going? give us an update
Old Jul 5, 2005 | 11:20 AM
  #16
lt502000's Avatar
Default LT 50 Mods?
The nerfs are on an they look great!!!! This mod took a little more work than exp. The nerfs were 15 in. wide so i had to extend the swingarm 3 in. a good buddie of mine works at a fab shop so i took off the swing arm and added 3 in. and then painted it aluminum cant even tell it looks better now than ever. When i did this i also put 2 in. wheel spacers. My son loves it , it went from stock length n with to 3in longer n 4in wider and his favorite thing about this last mod is most def. the nerfs he loves them. when you look at the quad it looks like the coolest mini lt 250 you ever seen with the engine open you can also see the pipe n K@N filter. wish i knew how to put pics on my page would post them cant figure it out. Well let you know how the little 50 n my 4 year old do at the track there both ready.
Old Dec 29, 2005 | 03:39 PM
  #17
bulldogfallon's Avatar
Default LT 50 Mods?
Actually I believe that the K&N Part number is 62-1514
http://www.knfilters.com/search/prod...x?Prod=62-1514
I rec'd this info from CT and then checked it with the K&N Site....
Old Mar 23, 2006 | 10:26 PM
  #18
aussieboy1's Avatar
Default LT 50 Mods?
Hi there Aussie ATV
I see that you gave a email address for the aussie company that did these hop ups Do you have a phone number for these guys as lm a ex aussie living in Auckland and have a couple of boys racing these bikes at the moment..
Cheers Lance...
Old Mar 26, 2006 | 08:39 PM
  #19
aussieboy1's Avatar
Default LT 50 Mods?
Hi aussieatv
Do you have a phone number for this company called Quadmad racing, l have tried to email but have not had a return one for about a week and a half please helpm out if you can
C heers lance
Old Mar 26, 2006 | 11:42 PM
  #20
Kevvy's Avatar
Default LT 50 Mods?
Hey Thats me!
I have had email dramers so had to change now quadmad_kev@yahoo.com.au I am happy to help anyone.
Lance you can contact me by phone anytime just phone +61 412 557 977 .
Hey here is a handy hint for all you guys, with the clutch use Polaris 90 springs and that will up the revs before the clutch grabs.....it does help. my spacer helps heaps also.
Another thing.....use fity (CRF50, Thumpstar, SDG etc) shocks as the stock shocks dont work. there is so much you can do to this little machine.
