Milling the head on a JR 50
Old Jun 16, 2003 | 11:06 PM
Chuckzie's Avatar
Default Milling the head on a JR 50
Nyroc on the kawaie forum was suggesting milling the head on the suzuki 50s head to raise the compression to 8 to 1, has anyone here done that? And if so how much did you mill off the head? Was there any problem? (high octane fuel?)
thanks Chuck
Old Feb 3, 2004 | 10:59 AM
pinch's Avatar
Hi, Im about to mill the head on my daughters LT50, I should now this weekend how it turned out, will let you know then.
Regards Evert
Old Feb 3, 2004 | 11:59 AM
Chuckzie's Avatar
I milled my sons .03 last summer after I made this post. It worked out well, but I had to jet up the carb because the engine wanted more fuel then. It help topend, not low end like I thought it would. I will just have to change the cog to get a low gear ratio.
thanks
chuck
Old Feb 3, 2004 | 03:24 PM
pinch's Avatar
Hmm.....ok, I have also milled it down, but not put it back together again.
I was also going for the low end, but I will have to try it out and then continue to other
mods.
Regards Evert
Old Feb 4, 2004 | 12:54 AM
confusedbuyer's Avatar
cleaning gasket off my '85 LT50 cylinder, I put a gouge on edge. buddy milled the cylinder for me, about 2-3 thou. i think this would have same effect as milling head. I know it was faster and peppier than another friends lt50 afterwards. he was alittle worried about clearance, but it wasn't a problem.
don't know if this is relevant or helps you.
Old Feb 9, 2004 | 03:22 PM
pinch's Avatar
Hi,
the testdrive today with the milled head worked out great !!!
It did alot on the bottom and not much at top.
Now it has the power to get it started in hills and bumps even with me (160lbs)
I milled the top down 3mm, didnt have to rejet either.
Regards Evert
1ArmBandit
55
Oct 14, 2015 09:03 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Sep 23, 2015 06:23 AM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
