HP 300 Jetting @ sea level
Old Dec 2, 2003 | 08:03 PM
LTSRFASTER's Avatar
Default HP 300 Jetting @ sea level
any body running ther gas gas at around sealevel ? if so what size main jet are you running. Im going to glamis next month on the 20th and want to be prepared with the jets i may need to run well. Its stock - with the LTR kit for the power valve expansion and jet kit, main right now is 175 pilot is 50 right now i think. It seems a just a touch rich and im running at around 4000' in utah.
lets talk GAS GAS 2 stroke power
03 HP 300 22-11-10 8 PADDLE HAULERS ON C-SERIES W/ MOWHAWKS UPFRONT 13-44 GEARING
88 LT 500R
91 LT250R
Old Dec 4, 2003 | 05:31 AM
dual-sporter's Avatar
i'm running the LTR kit & PV cover too... i'm almost always between sea-level & 2500 ft. i run a 185 main, needle on clip position #3, 50 pilot, air screw out 2 turns.... seems a little rich on startup, but once the motor is warm, it is very crisp. for the dunes this jetting should be fine.
ReconBayou
Oct 31, 2022 05:37 PM
Beeline08
Nov 11, 2016 04:00 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
