I need some E-ton performance help!!!
Old Feb 12, 2004 | 09:10 AM
Voc's Avatar
Voc
Default I need some E-ton performance help!!!
can you elaborate on why you need to junk the oil unit in favour of premix?
Many thanks I am new to this and appreciate you guys sharing your knowledge
Old Feb 12, 2004 | 12:40 PM
2Gordons's Avatar
Sooner or later it will fail, then you will be rebuilding the motor. Also when you add the pipe and other performance mods, you will increase the gas consumption, the injectors were not designed for this, and will not be able to keep up with the gas consumption. = motor failure
Old Feb 12, 2004 | 02:18 PM
fishslab's Avatar
If my daughter were to race I might remove the oil injcetion. For now I plan on leaving it alone. I know the old mantra is the injection systems fail, but I have not seen that as a real problem. They increase injection with rpms so they get extra oil when reving higher. If something does go wrong I'll be the first to say you told me so. [img]i/expressions/face-icon-small-smile.gif[/img]
Valder
Nov 28, 2020 07:38 AM
Customer Service #1
May 15, 2020 08:46 AM
Sep 30, 2015 01:37 AM
jankerstien
Sep 21, 2015 03:09 AM
