Exhust Question?
Old Mar 28, 2004 | 12:45 PM
Bluetickracing's Avatar
Default Exhust Question?
I put a DG exhust on my sons 04 Arctic Cat 50. This exhust doesn't have the expansion chamber like the stock exhust has. I was wondering If the stock exhust would be better than the DG? Or should I get a pipe from WRH or Hetrick. I added alot of other mods on when we put the DG pipe on so I don't know if the DG pipe helped at all. Here is a list of mods I put on to help answer the question. Malossi clutch kit, DRR cdi, Malossi reed block and fiber reeds, Twin air filter and modifyed air box,95 main jet,changed sprockets from a 50 t rear to a 32t, changed wheel sizes went to larger dougles alum 16x6.5x8 and holeshot tires, the stock set were way to small for XC racing. Any help would be greatly appreciated.
__________________________
02 Yamaha Big Bear 400 4x4 -mine
01 Polini x3 works #838-Michaels
01 Husqvarna cr50 Jr#838-Michaels
03 Suzuki lt-80-Michaels
04 Arctic Cat 50#838-Michaels (DG pipe, Malossi clutch kit,Malossi reedblock and reeds, DRR cdi,Twin Air filter and Modifyed air box, 95 main jet,Dougles Alum wheels 16x6.5x8, Holeshot tires,)
04 Suzuiki DRZ-125 mine
Old Mar 29, 2004 | 01:59 PM
geo's Avatar
geo
Well, since you're asking the question, I'm guessing you're not impressed. After installing several other pipes on various machines, my overwhelming reaction has always been WOW. If you didn't have that reaction, I'd start looking elsewhere. A good performance pipe (with a decent size expansion chamber) will double the stock hp. That's easily noticeable by the rider. 10-20%, maybe not. Next to porting/cylinder, there's no single engine part you can add that can add that much performance.
Old Mar 29, 2004 | 04:06 PM
oldyeller's Avatar
If the pipe doesn't have an expansion chamber it is probably not as good as the stock unit.The arctic cats have a pretty decent designed pipe compared to most mini's.I haven't heard good things about DG pipes in general,wether it be for dirt bikes or snowmobiles or whatever.A lot of times of heard of power loss compared to the stock pipe.If your looking for more power I would contact the guys you mentioned.
EIF
Apr 20, 2017 07:15 PM
shimanok2
Jan 29, 2016 07:37 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
