anyone know anything about kasea
Old May 8, 2004 | 12:08 AM
quadracerNC's Avatar
Default anyone know anything about kasea
I have a kasea mighty mite 50 and it ran fine untill the other day it just shut off and will not crank anyone have any suggestions
Old May 8, 2004 | 02:55 AM
rscoyote's Avatar
If you have gas, is your plug fowled or wet? Does it have spark? Pull the spark plug and ground it with the bike turned on. Don't touch anything metal and turn over the motor. If it shocks the hell out of you, you touched the plug and you probably got spark. But look for spark in the end of a new plug. If you have spark do you have gas getting to the carb? Pull the hose off the carb, does gas run out?
If no spark use a multi tester and see if you have any AC voltage (around 120) coming off the magneto. If so do you have any (I Believe it is) DC voltage (about 6-14) going into the coil. If not I sayjest changing the CDI box they go out some times.
You may have dirt between the seat and the needle in the card. If you don't get a $2 in line filter before you do.
That's just a start. The first four things I check when a motor quits running are: Fuel, blocked airway (choke on?), spark, & compression.
You need about 85-90 lbs compression for the thing to run. Over 125 lbs is good compression
Good Luck...... And I'm not motorcycle mechanic.... But learned from the school of hard knocks.
Old May 8, 2004 | 09:45 PM
yes the fire is good it is gettin gas i even rebuilt the carb to make sure it is getting compression how much i dont know i guess i'll get something to test how much compression it's getting
Old May 11, 2004 | 01:48 AM
confusedbuyer's Avatar
what is it doing, "ying,ying, ying, ying, " but not actually starting? Or no noise, nothing? Did you try to kick start it? (you need to engage the brake lever to kick start, can't recall if it's foot or hand-try both). I do recall dealers said they were bad for CDI's, but I don't know if that would cause you not to start. i know our battery was just a little weak and wouldn't start, so we used jumper and it started.
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
ghost3
Jul 19, 2015 08:46 PM
daddy1st
Dec 12, 2003 09:03 AM
LB
Oct 17, 2003 12:20 AM
