Electric Start
Old Nov 5, 2004 | 04:26 PM
papermaker's Avatar
Default Electric Start
I have a redcat 50cc. When I try and start the engine (electric start) I get no response. I charged the battery and checked the connections and seem to be ok. Can anybody tell me how to diagnose the problem?
Old Nov 5, 2004 | 04:51 PM
Phantom76's Avatar
Have you tried jumping a wire directly from the battery to the starter to see if it turns?
Old Nov 5, 2004 | 07:06 PM
Bluetickracing's Avatar
Do you have to have the brake lever pulled in to use the electric starter? If you do the conector on the lever may not be pulled in all the way. I had this problem once. The rubber boot pulled out just a little push it back in and try that.
Old Nov 6, 2004 | 06:46 AM
KILLEREX's Avatar
ckeck the fuse
Old Nov 10, 2004 | 07:32 PM
bxborn's Avatar
There is a relay switch That may have gone bad .It happened to my sons sunray . You can remove the relay and jump the switch. It should crank. Good luck
Old Nov 11, 2004 | 08:27 AM
papermaker's Avatar
Thanks for the reply, can you tell me where this Relay switch was located on your son's quad?
Old Nov 11, 2004 | 06:56 PM
bxborn's Avatar
The relay on my sons quad was under the seat. you will see a small square box with wires running to it from the electric start. Mine was brass in color. Good luck
4xrider
Apr 10, 2017 01:36 PM
Mikes350X
Nov 20, 2000 04:04 PM
rmx251
Sep 10, 2000 11:40 PM
Dom
Aug 3, 2000 08:04 PM
4trax300ex
Jul 29, 2000 11:41 AM
