HELP WITH YAMOTO 150 mods!!!!!!!!!!!
Welcome to the forum yamoto150owner, The front shock's can be replaced with stock shock's from a suzuki lt160 or from a eton 50/70/90. As for the rear I could not find anything that would bolt right in. You can soften the front by swaping front tires around, putting the valve stems inside. This will widen the front end and put more leverage on the front shock's. Makes a huge difference and very cheap. I replaced the stock muffler with a modified Answer S/A pro spark arrester. I made a plug to go in the end of it to bring noise level back to stock. I have no idea where to get a different sprocket. What do you want more speed or more grunt??
Originally posted by: yamoto150owner
Thanks for the welcome. I have a question for you, which shocks are better the suzuki or the eton?
As for more speed I have opened up the breathing, new filter/replaced air box and muffler. I have also recently replaced the wheel bearing's with higher quality version's. It has not been ridden since these mod's. I will be clocking it's top speed in approx. 2 week's, And will post a review under Yamoto 150cc Review. Top speed before mod's, 32mph.
Thanks for the tips and tricks
Where can I get an Answer S/A pro spark arrester
Customer Service #1
May 15, 2020 08:46 AM
kbazzy
Sep 26, 2015 11:26 AM
Sep 23, 2015 06:23 AM
