83 alt50 no start
Old Mar 25, 2005 | 05:40 PM
bornslippy's Avatar
Default 83 alt50 no start
Hi i have a 83 suzuki alt50 and i cant get it to fire up at all, it has a new plug with plenty of blue spark new rings mix gas in the tank compression seems ok i cleaned up the exhaust port, totally dissambled the carb and cleaned, new float. when i try to pull start it, it seems as if gas is forced through the carb toward the air filter. any help would be awesome
Old Mar 25, 2005 | 09:25 PM
newnick's Avatar
Check the reeds.
Old Mar 26, 2005 | 02:31 AM
hondabuster's Avatar
I didnt think that motor had reeds, anyway, check the float level, it may be too high, or the air bleed in the intake side of carb may be plugged.
Old Mar 26, 2005 | 05:23 PM
bornslippy's Avatar
yeah i dont think the motor has reeds. Where is the bleed valve at on the top of carb?is it the one that i have a vacuum line coming off and going to nothing? And how can i check float level? thanks for the help.
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 26, 2005 | 09:59 PM
newnick's Avatar
Are you mixing oil with the gas?
Old Mar 27, 2005 | 02:28 AM
Turning the carb upside down and measuring the float...it should be .96 to 1.00 higher than the mating surface,
vacumn line going to nothing? Does it have a pri position on the fuel valve on the gas tank? then its a vacumn valve and that vacumn line needs to go there. If nothing else...for now plug the line and turn the valve to pri. Its posible there is enough vacumn lost having this line disconnected, that it will prevent starting.
The air bleed is in the air filter side of the venturi, running parallel to the air flow. Its a brass insert in the aluminum body, and has a very tiny hole.
Old Mar 27, 2005 | 09:55 AM
bornslippy's Avatar
Thanks for the info i'l try it and let you know. it seems wierd that i cant get it to do anything you would think it would at least make a pop or backfire or something.[img]i/expressions/face-icon-small-disgusted.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-shocked.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Mar 27, 2005 | 09:58 AM
bornslippy's Avatar
yeah i dont use the injection system
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
