kazuma falcon 110 questions
Old Jan 18, 2006 | 11:25 AM
  #51
F6Hawk's Avatar
Default kazuma falcon 110 questions
It seems no one spotted my question about chain tension....
What is the recommended tension on the chain? Is it 3/4", measured at the bottom of the chain, pushing up from slack position? Or does Kazuma have a different recommendation?
TIA!
F6
Old Jan 18, 2006 | 01:28 PM
  #52
mud91's Avatar
Bought new 110 falcon, which way are the fuel valves suppose to be for on...
Old Jan 18, 2006 | 03:36 PM
  #53
BigJon's Avatar
Are you guys only getting the spacers for the front or are you doing the rear as well?
Old Jan 18, 2006 | 03:42 PM
  #54
mud91's Avatar
the fuel valve on the left is the cut off from the tank, whats the one on the right side...
Old Feb 5, 2006 | 02:40 AM
  #55
SHAGGY951's Avatar
I just bought my kids a falcon 110 for christmas. It was fine for a month but now when you give it gas it will run and rev up fine but it will barely move. Any suggestions on what it could be?
Old Feb 5, 2006 | 10:26 AM
  #56
2manytoys's Avatar
Shaggy did you check all the brakes to make sure nothing is stuck? Does it bog down when you give it gas while in gear or does it just rev up?
Old Feb 5, 2006 | 11:33 PM
  #57
10000's Avatar
I HAVE A 110 AND IT POPED AND QUIT RUNNING I CHANGED THE SPARK PLUG AND IT RAN FINE.
Old Feb 6, 2006 | 03:14 AM
  #58
SHAGGY951's Avatar
No it runs fine and I checked the brakes and nothing is sticking. it don't bog down at all. my kids are bumbed.
Old May 2, 2006 | 04:31 PM
  #59
TurbineTim's Avatar
Need some info. I bought The 110 Baby Falcon in Dec, Things are starting break and can't get the dealer to get me parts. Axle broke off at wheel hup, 2 studs broke off from drive gear on axle, front shocks are bad, tires lean inward real bad. Hoping I don't get took on the ATV anybody got a # for waranty service. I'm in west TN. I have requested shock since January and he just will not send them. What is a person to do, besides spend more money and buy them out right.
Turbine
Old May 2, 2006 | 10:28 PM
  #60
2manytoys's Avatar
Turbinetim,
Who was your dealer? You can call Kazuma direct and tell them the situation or if you really need parts you can call Raceway atv and talk to John. He can get you parts.
