Predator 50cc problems
Old Dec 12, 2005 | 03:47 PM
dwallace's Avatar
Default Predator 50cc problems
Just purchased a Predator 50cc new. After one week was in shop because only would idle. Would die when you give it gas. Mechanic said it was smothering or something and should be operated wide open throttle to blow out oil. It has started doing this about once a week and I have to remove air filter and baby it until it will run wide open and then is fine for about a week. Smokes alot once it hits full throttle and then burns clean. Is this a normal problem or just with two strokes. Anyone know how to fix. Any help appreciated
Old Dec 14, 2005 | 05:37 PM
billl2099's Avatar
not normal, what ratio are you mixing the oil and gas or is it injected? should be mixing around 40:1, it might smoke a little when cold, sounds to me to much oil.
bill
Old Dec 15, 2005 | 11:14 AM
dwallace's Avatar
It is oil injected. I believe the first tank of gas had an oil mix by the dealership but since no oil has been added. I was wondering if to much oil was beening injected and if that can be adjusted?
firsttimerider
3) General Discussions..
Aug 9, 2015 09:54 AM
hondarider1234
Jul 21, 2015 11:53 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
steveo612
Jul 11, 2015 08:35 AM
