06 sportsman 90 lights
Old Dec 16, 2005 | 06:30 PM
watzupdog's Avatar
Default 06 sportsman 90 lights
Can someone post a pic of there pred 90 or sportsman 90 (prefer sp90) with the daytime running lights on. I havent seen it yet. Thanks
Old Dec 17, 2005 | 10:47 AM
spike99's Avatar
Surf entire contents of:
http://community.webshots.com/album/283371980xEWfck/0
http://community.webshots.com/album/283371980xEWfck/1
Detailed Instructions are:
To install lights on our '03 Predator 90 (which is very simular to many 90ccs that contain a battery) here's how I'd do it again....
1 - Purchase 12V rated toggle switch.
2 - Purchase inline fuse.
3 - Purchase 12v MR-11/20W automotive fog lights. For a picture, surf:
http://community.webshots.com/photo/...44077091YvhgRb
4 - Purchase 12v MR-11 10W bulbs. For a picture, surf:
http://community.webshots.com/photo/...89398535PAZfDQ
5 - With items from 1->3, install the parts. For pictures, surf:
Hard Wire via Top diagram of: http://community.webshots.com/photo/...83373282dBxgoZ
Switch: http://community.webshots.com/photo/...83373686wGAAwr
Front lights: http://community.webshots.com/photo/...83372615AHxNQe
Note: Install a relay and connect it to an unused ignition OFF/ON wire (as shown in lower wiring diagram) to turn the lights automatically off when the ignition key is turned off.
6 - Use 2 x MR-11 20W bulbs in the factory lights. If it drains the battery, downgrade one bulb to MR-11 10W bulbs (see above 4).
7 - Run 1 x 10W and 1 x 20W bulbs. If it drains the battery too much, down grade both bulbs to 10W bulbs.
To allow tail light to use less power (thus allowing more power for front lights), replace rear bulb with LED bulb. For our LED rear bulb, surf: http://community.webshots.com/photo/...48560967RRGsmT
End Results on our Pred-90:
http://community.webshots.com/photo/...48850806iKnBSm
http://community.webshots.com/photo/...48850618ZNbrkA
http://community.webshots.com/photo/...48850884HgSkde
If you want to run brighter lights (without draining the battery), contact folks who can provide a high output stator for your mini. Folks who come to mind are:
- Ricky Stator - see below.
- An experienced electrician who can re-coil your factory stator. If installing a higher output stator, then a better regulator may be required. It depends if your regulator was built to take more input power.
For pictures of other sites with mini-Quad light info, surf:
http://www.lt80lightkit.com/
http://www.xtreme-4x4.com/ATV_Lights.htm
http://www.jcwhitney.com/product.jht...=376590&BQ=atv
http://www.driving-lights.com/atv_light_kit.html
http://www.rickystator.com/pages/Lig...20systems.html
Notes
1 - The above folks also sell "bolt on" kits and/or generic kits that can be installed on your battery based 90cc system. As a suggestion, always try only use lights that stay 80% under your stator/regulator's MAX output. Thus, reducing stress on the factory stator and remaining 20% can be used to re-charge the battery. The Pred-90 stator system has a output range of 32 - 38 Watts. Our first stator was 36 watts and our replacement stator is 32 watts. Each mini is different.
2 - Some folks like installing a single light (re: http://www.lt80lightkit.com/ ) and others like dual front lights. For me, I like dual front lights much better. We replaced our original single lights with dual lights. Dual lights shine infront of the tires - where most young riders keep visual focus. A single light doesn't shine to the front wheel areas "as good".
If you plan to re-coil your own stator system, surf:
http://www.50mod.com/stator.php
http://home.comcast.net/~pgailunas/stator.html
Note: If re-coiling, may want to ensure your stator can "pump out" 90 Watts of power. Thus, allow you to install 2 x 35W front lights, Tail Light, Brake light and still have power left over to charge your mini's battery. For example, create the same system located at: http://www.rickystator.com/pages/TRX...ing%20kit.html
Hope this info helps....
Old Dec 17, 2005 | 05:23 PM
watzupdog's Avatar
Hey spike
Thanks bud for the great info. What I meant was could someone post pics of there 06 sp90 or pred that comes with the factory lights already installed. But I can see myself using that info for the future. Thanks again.
bzdok1234
30
Feb 23, 2016 01:55 PM
kodiak450.
Utility ATVs
13
Jul 27, 2015 05:07 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
