articat 50cc question
Old Jan 23, 2006 | 05:04 PM
allstardj's Avatar
Default articat 50cc question
need to find where govener for articat 50cc 2004 is
Old Jan 23, 2006 | 08:24 PM
Fastestdad's Avatar
Which one are you looking for? It has a restrictor in the carb that only lets the slide open 1/2 way up. It has a top speed governor in the front clutch (variator) that governs top speed. It may or may not have a revlimiter in the cdi box as well. A new cdi is pretty cheap if you get the right one its an easy fix. Under $40. Also you can remove the smallest exhaust outlet from the tailpipe and spend $3 on a mainjet 2 sizes up, that helps a bunch.
Old Jan 23, 2006 | 10:49 PM
Bluetickracing's Avatar
Well here ya go. The cdi is a limiting cdi. The 50 tooth rear sprocket is another limiter. There is a washer in the air intake tube . The 16" tires are to small also. The quad really rev's up to fast with the smaller tires and the 50t sprocket. Pull the clutch cover off. Looking at the quad from the side with the cover off. The variator is on the left. Remove the nut holding the 2 variator halves together.There is a small spacer inbetween the 2 halves. It looks like a wide weding band. It keeps the 2 halves from going together which keeps the belt from riding up higher on the ramps not letting it go faster. If you keep the 16" tires you might want to go with a 27 rear sprocket.
If you need any stock parts give me a PM. I have lots of stock parts. I also have a like new Malossi reed cage and carbon fiber reeds. I have a set of stock tires and wheels which NEVER were used.
If you need any help just PM me. I've built our's from the ground up more then once!
Old Jan 24, 2006 | 10:52 AM
Fastestdad's Avatar
If you need a cdi box for a 50 cat I have one I'd let go cheap.
Old Jan 24, 2006 | 01:16 PM
accwiz's Avatar
Do you think that the CDI that you have for the AC50 will work in a 2006 AC DVX 50?
Old Jan 24, 2006 | 08:57 PM
allstardj's Avatar
thanks for the info took it to dealer and he sain there was no gove in clutch. took throttle srew all the way out amd the is no difference in speed from half throttle to full throttle, also what should top speed be on it stock
Old Jan 25, 2006 | 01:22 AM
Fastestdad's Avatar
accwiz I havent quite figured out what is going on with the 4 stroke quads they have so many different things they are using and from so many different suppliers. They used to be very generic PM me your email address if you want and I'll send a pic. I could always send it to you to look and you could send it back to me.
Old Jan 25, 2006 | 10:25 AM
accwiz's Avatar
FastestDad, I know about the 4 stroke differences. I spent tons of time looking for the limiters on this thing. It had a clutch limiter as the older models did but I still think that their is a limiter on the CDI. Is the CDI a stock CDI, or does it have higher output than stock?
bigred20653
Oct 2, 2015 10:05 AM
firsttimerider
Sep 20, 2015 09:07 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
bigred20653
Sep 19, 2015 02:11 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
