90cc alpha sports quad question
Old Jan 25, 2006 | 05:09 PM
DanCaffo's Avatar
Default 90cc alpha sports quad question
Ok i have a 2002 alpha sports 90cc quad that im having alittle problem with. Whats wrong is the quad starts and idols but when i press in the throttle its like it can get enough power to go anywhere and when you press the throttle in further it will stall out. Any info on how to fix it would be greatly apreciatted.
Dan
Old Jan 25, 2006 | 07:18 PM
Hymis's Avatar
Sounds like the carb. Make sure the carb is getting fuel. Might be the jetting or a fouled plug. If its a 2-stroke the carb might be gunked up and the floats are sticking.
Old Jan 26, 2006 | 12:15 AM
DanCaffo's Avatar
ok thanks ill try cleaning the carb and even though the plug looks good ill change it.
Old Jan 26, 2006 | 03:14 AM
Randes's Avatar
I had the same problem and it was a clogged fuel filter.
Timdaddyo4
Ask the Editor
Apr 27, 2024 06:50 AM
Frisky2050
Apr 9, 2020 11:19 AM
DOC HOLIDAY
Jul 9, 2015 01:09 PM
yambam13
Jul 4, 2015 01:49 PM
D-Hagz
Jul 4, 2015 02:19 AM
