Wheel Spacers For SUNL 70???? ANYONE???
Old Mar 22, 2006 | 09:19 PM
PDRACER440's Avatar
Default Wheel Spacers For SUNL 70???? ANYONE???
Just wondering if anyone has been able to locate wheel spacers for the SUNL 70? As most of you are aware they seem to be a little narrow and I would like to give it a slightly wider stance if possible. I found several for the kazuma's and several others, but I dont believe they will fit the SUNL's. Please throw some ideas my way.
Old Mar 22, 2006 | 09:44 PM
2manytoys's Avatar
I made my own. I just went to Home Depot and got longer bolts, alot of nuts, lock washers, and about 2-3ft of conduit. I cut the conduit to the width that I wanted. I put the new bolts in the hub, put the conduit on and put a nut to hold the conduit. Then I put the wheel on, lockwasher then nut. It has worked great . Only cost about $10.
Old Mar 22, 2006 | 10:36 PM
RAMTechRC's Avatar
I was going to make my own, but I found Metric coupler nuts that were around 3/4" long. I used 2 of them per stud, with a threaded stud inbetween. Then a hex head screw to hold the rim on. I think it cost me around $25.00 though. Should have made my own. Next time.
Old Mar 23, 2006 | 08:45 AM
jdr00ejr's Avatar
I'm having trouble visualizing this on my SunL 70. You got a picture you could maybe shoot me an email?
Old Mar 23, 2006 | 09:20 AM
RAMTechRC's Avatar
I'll sketch something out and put it on here tonight.
Old Mar 23, 2006 | 10:29 AM
billl2099's Avatar
i did almose the same as 2manytoys, i purchased 10.9 hardness bolts,washer and nuts, i also used steel tubing id same as the od size of the bolt, i spaced the wheels out 2 inches each to add 4 inches toal width, the cost was around $50.00 for 2 quads and i spaced all four wheels on each atv, it seems to make a hugh differance.
Old Mar 23, 2006 | 10:32 AM
jdr00ejr's Avatar
I'm interested in RamTechRC's sketch....but I'm also curious if you have any pictures of your setup?
Old Mar 23, 2006 | 02:42 PM
Jester125's Avatar
Does anyone know the thread size?
I bought 2 pairs of spacers on ebay for my Sunl 90 and they dont fit, there too big.
The seller says that the thread size for the spacers are 10X1.25mm and I was just gonna drill out the hubs and wheels to fit them in but I need new lug nuts and bolts and I cant find anything in that size.
Chris
Old Mar 23, 2006 | 02:47 PM
RAMTechRC's Avatar
The thread is M6. When you look at a bolt, it just doesn't look big enough to be used on a quad. I'm used to the M10 size for stuff liek this.
Old Mar 23, 2006 | 03:55 PM
Jester125's Avatar
thanks
