yamaha raptor 80 wont turn over
Originally posted by: tkbayes
Rear brake is a foot peddle and the front brake is the right hand lever
Well, no good luck.
I pulled each top valve cover off, and see nothing wrong, but it is locked up. The exhaust valve is open as I thought by looking through the spark plug hole. The intake valve lash looks fine.
I pulled left side cover off, cam sprocket will not turn motor over... also tried to turn clutch drum, no luck.
Had sprayed WD-40 in cylinder, and let sit, still no help, so I do not think it is just stuck rings. Bike roles fine in neutral, but is locked in every gear, so I really do not think it is the transmission either. Also no rear end noise and pushed easy in neutral, so I doubt rear end is bad.
I do not have a manual for this motor. If I mark cam sproket and chain for timing, then pull top cylinder off, is there anything else I need to mark, or remove before pulling head and jug?
I am traveling again, so will be a few days before working on it...
Thanks for the help! Please keep it coming.
to bad you have friends you think you could trust, now you know why the atv been sitting for two years, i could see the carburator going bad just sitting their for two years if the gas wasn't run out it, but the engine just isn't going to break sitting, what i do next would be to drain the oil ,( if their is any) and look for metal, the oil is usally the first indiciator of engine damage
bzdok1234
30
Feb 23, 2016 01:55 PM
Jul 7, 2015 11:00 PM
