Racks and accessories
Old Jun 8, 2006 | 01:21 PM
ttaylor's Avatar
Default Racks and accessories
I picked up an E-ton 90 DXL for my kids. I am wondering what kind of accessories are available? I know there are lots if I wanted to set it up as a racer but I want a trail machine. I will leave the motor and pipe stock for now until my daughters get a handle on the riding.
I would like a rear rack and possibly a front too. dual state foam filter, wheel spacers. any info would be appreciated.
Old Jun 8, 2006 | 09:27 PM
hoytultratec's Avatar
wheel spacers
www.speedtrapmotorsports
Old Jun 8, 2006 | 09:45 PM
atvmike92's Avatar
Uni air filters are dual stage. You can find them cheap at rockymountainatvmc.com
This place also sells front and rear racks for a suzuki lt80. That should work. And racewayatv
makes wheel spacers for a 110. Try fitting that. All of these parts together will cost around
$300.
Old Jun 9, 2006 | 10:33 AM
ttaylor's Avatar
The LT 80 filter will fit the E-Tons?
Old Jun 9, 2006 | 11:05 AM
atvmike92's Avatar
If you get a uni clamp-on filter they give you the carb sizes that they fit on. Your carb on the 90 is probably 18-26mm.
Old Jun 9, 2006 | 11:21 AM
ttaylor's Avatar
I assume then that would require the removal of the air box?
Old Jun 9, 2006 | 11:34 AM
atvmike92's Avatar
Yeah. But its pretty easy to do, though. And the stock air box might not be able to fit an
aftermarket air filter. The way mine was designed it couldnt. And you might get cleaner air
putting it directly onto the carb.
badgerboy1
Sep 26, 2017 06:11 PM
TLC
Utility ATVs
Sep 16, 2015 01:41 PM
carid
Sep 14, 2015 03:40 PM
