Remove Oil Injector on Predator 90
Old Aug 28, 2006 | 04:52 PM
Dan12P's Avatar
Default Remove Oil Injector on Predator 90
I have a 2003 Polaris Predator 90. It seems to run good one day, bad the next. I wonder if the oil injection may be part of the problem. I am in the process of removing the oil injection system and I'll just use pre-mixed gas from now on. I have removed the oil bottle, plugged the oil line to the carb, and plugged the oil lines to and from the oil pump. Do I need to do anything else? How do I deal with the electrical wires going to the oil bottle? Cut the wires and connect them?
I'm sure this topic has been covered before, but I've spent the last hour trying to find these details and I couldn't. If you've been there done that, please pass on your wisdom.
Thanks!
Old Aug 28, 2006 | 05:17 PM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
You'll still need to rejet. The electrical wires to the tank go to the low oil light. You can remove it.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
craacker
Sep 9, 2015 04:32 AM
