DS50 Bomb running great!!!
Old Jan 21, 2007 | 10:28 PM
  #21
jutcie's Avatar
Default DS50 Bomb running great!!!
i just bought a 2002 bombardier ds50 for my son and it feels like it is rev'd out when full throttle.any way of making the 50 faster without engine work?i was told i can remove a slug in the intake and replace the cdi box.is this all safe to do for the engine?also was looking for some wheel spacers to make it a bit wider.anyone know of a company that sell aftermarket proformane parts for this quad?any help would be great...thatnks...also does anyone know where i can get a good used service/repair manual for this quad.thanks...peter
Old Jan 22, 2007 | 01:12 PM
  #22
Fastestdad's Avatar
Did you read the first page of this post?
Old Jan 22, 2007 | 02:26 PM
  #23
teampacifica's Avatar
I just bought a manual on e-bay just type in bombadier ds 50 manual and they send it to you on disk! I think the seller is like foxmoto manuals or something if you cant find it write back and ill find my invoice for you!
---Still waiting to see if anyone has any info on the no spark and oil injection, and where is the slug in the intake I cant find it!
Old Jan 22, 2007 | 10:07 PM
  #24
jutcie's Avatar
i looked for the foxmoto manual link but cant find anything.could you try to find the invoice and give me a number?thanks alot.maybe fastestdad can help you out with your no start condition,he seems to have alot of knowledge about these little quads. good luck.wish i could help but i'm just getting into this sport/hobby so i dont know much.thats why i ask stupid questions.
Old Jan 22, 2007 | 10:35 PM
  #25
jutcie's Avatar
jetTurbines,does your electric start and your kill switch still work after installing the cdi?also,isnt the slug/brass washer inside the carb?i called hetricks today and they said there was a brass washer in the carb that has to taken out by removing the 2 screws on top of the carb.and has to be pulled out the top.(is that true?)(is that what you did?) and there is there anything in the intake pipe?thanks.
Old Jan 23, 2007 | 02:41 AM
  #26
gmc400ex's Avatar
http://www.provoscooter.com/shop/pro...products_id=87
this web site show's great how to's. They are on scooters but they are them same motors on these tiawanese (sp?) motors.
hope this helps sombody.
Old Mar 2, 2007 | 02:49 AM
  #27
g22bob's Avatar
Does the CDI box from Scooter Assassins come with directions? It doesn't look like it matches up. I have a 2002 DS50. I see another box in there 1 1/2" X 1 1/2" silver in color with a 4 wire plug the schematics say this is a "pacifier" does that mean restictor? I unpluged it and ran fine just not faster. what the heck is this thing if it runs the same with or without it pluged in???
Old Mar 3, 2007 | 01:54 PM
  #28
gmc400ex's Avatar
I traced the wires to that silver thing and it ended up to the electronic choke. (on the carb)
Old Mar 3, 2007 | 01:57 PM
  #29
gmc400ex's Avatar
Where exactly is the slug on the intake? Do I need to take the reeds out with intake? I have an 04 and 05.
Old Mar 3, 2007 | 02:31 PM
  #30
g22bob's Avatar
The "slug" is a metal washer welded into the intake tube from the air cleaner. Pull off the tube (metal pipe) and on the carb end of the tube you should find the washer. I used my Dremel tool to grind off the weld, be careful the washer is stronger than the tube, you don't want to bend the tube. Also clean all the metal shavings off so they don't get in the engine.
