2004 Eton viper 50 rev limiter
Old Nov 11, 2006 | 10:22 PM
u's Avatar
u
Default 2004 Eton viper 50 rev limiter
Does anyone know how to disable the rev limiter on the Eton viper 50??
Old Nov 13, 2006 | 01:38 AM
oldyeller's Avatar
Yes..Remove the nose cone and on the right hand side(as you face it) you will see the cdi box in a rubber sleeve attached to a metal tab..You can just lift the rubber sleeve up off of the tab and pull the whole thing out.Slip the cdi out of the sleeve and you will see a green wire coming out of the backside of the cdi and going right back in.Snip the wire in two and tape the ends and you're done.Be careful you don't unplug any wires when you pull out the cdi..I have pictures if you are unsure what to do but its very simple.
Old Nov 13, 2006 | 06:02 PM
u's Avatar
u
Thanks, Your right it was simple. What else can we do to get a little more out of it?
Old Nov 14, 2006 | 02:08 AM
oldyeller's Avatar
It depends on how much more you want out of it.A higher compression head and better reeds will help a little.You can get a bigger cylinder and piston and make it into a 70cc..You can get a bigger carb and a pipe for big gains for bigger bucks..Clutching can really make it jump out of the hole....Or you can do it all and have a real screamer..
flyin-lowe
Dec 1, 2017 03:18 AM
2many2ride
Sep 27, 2015 04:35 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Bernhard
Sep 25, 2015 12:45 PM
Sw00p
Sep 24, 2015 02:50 PM
