JetMoto 150 Tranny Issue
Hey Everyone - love this Jetmoto 150 and still have faith in it but....the tranny slips big time and within a few seconds under load disengages completely. The chain tension is fine, we adjusted that. The rider is 65 lbs so weight isn't an issue...Any ideas??? Thanks for the help
samdrew,
Make sure the linkage to the reverse gear is adjusted properly. If the gear engages just enough it will act like it is in neutral. You will loose power to the rear wheels. If you suspect the problem is in the CVT the best thing to do is put the quad on a stand and pull the CVT cover. Start the quad give it throttle and see what happens.
SB.
SB.
Do you know how much swing there's supposed to be in that arm? Would an out of whack adjustment make it lurch and grab? It gets going, then feels like it looses it, catches and lurches, then continues until it spins as if in neutral. I'm not extremely skill in tearing these apart - really just trying to buy 12-18 months until he can physically handle a 250.
Welcome to the forum samdrew![img]i/expressions/face-icon-small-smile.gif[/img] Check the reverse lever on the rear end and make sure its all the way released. It moves back as it releases. There should be no tension what so ever on the spring that is attatched to the lever. If that checks out ok youi may have a faulty item in the CVT. Have you contacted the person you bought it from?
Thanks for the welcome... John at Raceway has been very helpful, he's going to locate a Jetmoto wrench turner around North Atlanta for me. We discussed that lever as well - the swing (movement) in that is minimal and the spring is slack. While I'm no mechanic, it seem like something inside is the issue - what's CVT stand for? We'll get it worked out...I was hoping for it to be something obvious as most of the major brand dealers what nothing to do with this bike. Thanks for the feedback
Thanks
